Results 1 to 11 of 11
Thread: First CYA Test
    Jul 2014
    Northern Minnesota
    51
    First CYA Test
    Just did my first test for CYA. I am using the 6 way HTH test kit from Walmart. The directions say to fill the tube until the black dot disappears and then read the level in ppm. The last mark on the tube is 30. I was at the top of the tube (just a little past the 30 mark) and could barely see the black dot. I'm guessing my level is around 20 or 25 but cannot be sure because I topped out. Is this acceptable?
    Also, my FC is 1.5. Depending on the day (amount of sunlight and/or use) I have to add bleach daily to get the level back to 4ppm. My PH seems to fluctuate between 7.1-7.6 daily. My water is crystal clear (though I've only had the pool for a week).
    Should I raise the CYA or keep as is?
    Intex 15 ft x 42" Above Ground Pool bought from Amazon (3, 284 gallons)
    Standard pump and cartridge filter that came with the set up (1,000 gph)
    I live in Northern, MN
    38,301
    Re: First CYA Test
    Sounds like your CYA is a little low. I would suggest adding about 10ppm to your pool and then testing it again in a week to make sure you are at least at 30ppm.
    Once you add the CYA, you should assume the CYA is around 30 ppm and use 2ppm as your minimum FC level ... you need to ALWAYS keep the FC above 2ppm. See the FC/CYA Chart. So maybe you should target 5-6ppm each day.
    Mid Missouri
    227
    Re: First CYA Test
    Also make sure you are performing the cya test correctly. Generally speaking outside with back to the sun, with the tube at about waist height. If you are holding the tube in brighter light or holding up to your eyes to "try" and see the dot, that's incorrect.
    It is normal to add chlorine daily. As mentioned once you know your CYA is correct, if you are dropping below your minimum regularly move your target up. That goes back to when I was telling you I keep my chlorine a couple ppm over on the target end to make sure I always stay above the minimum even on heavier load days.
    Jul 2014
    Northern Minnesota
    51
    Re: First CYA Test
    Quote Originally Posted by jcp View Post
    Ahhh...yes, that makes sense. Thank you!!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: First CYA Test
    Maybe a little show and tell will help your confidence: https://www.youtube.com/watch?v=Nxaq...9Y_YYNAeLtUr1g
    In MN you likely can go with 30ppm CYA but you'd want that dot to disappear at 35 or 30. You are a little low on the chlorine and Jbilizzle's recommendations for your FC are good advise.
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2014
    Northern Minnesota
    51
    Re: First CYA Test
    Quote Originally Posted by kiss4afrog View Post
    Great video!
    Mid Missouri
    227
    Re: First CYA Test
    You brought up ph also. Just curious if you ever measured your total alkalinity.
    Jul 2014
    Northern Minnesota
    51
    Re: First CYA Test
    Are you suggesting I target 5-6ppm each day AFTER rising my CYA to 30ppm or UNTIL I get my CYA to 30ppm?
    38,301
    Re: First CYA Test
    After. See the chart. With a CYA that is 20-30ppm, the minimum is 2ppm ... you need to stay above that so target 4-5ppm.
    If your CYA ends up a little higher, you may want to target 5-6ppm.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: First CYA Test
    Quote Originally Posted by TrustJesus View Post
    He means as soon as the sock goes in the pool you should consider it all dissolved and present and target the appropriate FC level for your target CYA.
    Jul 2014
    Northern Minnesota
    51
    Re: First CYA Test
    I check my levels each day at the end of the day. My FC is usually between 1.5-3 after sunlight and use. I target and add the necessary bleach to get the level to 4ppm before covering the pool for the night. I'll up my target level to 5 from now on.
