Thread: New to Trouble Free Pool
    Jul 2014
    Dallas/Texas
    14
    Hello All!!
    My mother and I have taken the plunge to use the Trouble Free Pool method! Hoping to get a couple additional tips--
    1). When it rains-- in the past the pool store had us add shock-- do we still need to shock when it rains or go by our chemical results? And related to that if it rains for several days in a row--should we test daily during the rain or wait until it subsides?
    2) Is there a general rule of thumb for what order chemicals should be added? For example, last night we added chlorine and needed to also raise the PH-- both were added one behind the other--
    Thanks!
    Trying not to be overwhelmed!
    16,500 gal, IG plaster, restoration January 2014; 1 HP Energy Flo pump, 48 sqft DE filter-Hayward ProGrid 4820, 360 Polaris Sweeper; Taylor Complete K2006 FAS-DPD; Timer
    38,302
    Re: New to Trouble Free Pool
    Welcome to TFP!!!
    1) Rain has little impact on the pool's chemistry. Always test and adjust based on your test results.
    2) Not really. Good to wait at least a few minutes between adding bleach and acid ... certainly never want them to mix.
    Have you found and started reading Pool School? These will get you going:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    Jason has given you some good advice. I would just like to add, if you don't have a good test kit here are the Test Kits we recommend. The pool store isn't up to our standards of water testing. The results from one of these kits will enable us to give you good solid advice on your water chemistry. It's a small investment for the right tool for the job. 😎
    Jeff
    Jul 2014
    Dallas/Texas
    14
    Quote Originally Posted by pwrstrk View Post
    Welcome to TFP !
    Thanks Jason and Jeff! We have the Taylor K2006 FAS-DPD Complete Test kit.
    May 2013
    Fort Lauderdale, FL
    423
    I would just test for FC after a big rain, you might need a small bump from your normal addition especially if you get a lot of tree stuff blown in.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    One of the biggest misnomers is the one about rain and pool disaster. No need to shock after a rain. If you've been maintaining proper and adequate FC levels, rain will have very little effect. If you have six inches of rain, or surface runoff into the pool, this changes the game. Otherwise, usually not a big deal at all.
    Try to spend some time in Pool School. The best tool in your tool box will be knowledge. Start with the ABC's and work up from there. Don't be overwhelmed, it only seems like a lot right up front. Once you have the basics, it really is very easy.
    Essential Links:
