Results 1 to 14 of 14
Thread: Best time to test?
    Jul 2014
    Crowley,Louisiana
    26
    Best time to test?
    Just received my Taylor K-2006 and K-1766 salt test kits. Wondering what the best time to test is: #of hours before or after pump cycle,morning or afternoon. Normally run 3-4 hour cycles as reccomended w/Intex swg. Here are some notes: pool stays covered 98% of the time and swam in 2-3 times a month since the grandkids don't live with us anymore and don't get to jump in all time like they used to. With being covered for long periods should I run my sprinkler system during cycles and or uncover (can run sprinklers w/cover on). Also, should cycles be ran morning, noon or nightime as it is covered most of the time? Thank you, believe me more questions to follow.
    16x48 Intex above groud 6500 Gal. w/Krystal Clear (Intex) 16" sand filter & SWG system (2650 GPH). Two different homemade sprinklers, will post pics when I learn to use the forum better.
    38,275
    Re: Best time to test?
    Test at least 30 minutes after the pump has turned on. Add chemicals at least 30 minutes before the pump turns off.
    CYA test should be done in bright indirect sunlight. Beyond that the time does not matter. Good to be consistent though.
    Does not really matter when you run the pump.
    Mar 2014
    Las Vegas
    288
    Same time every day makes it easier to learn what your pool needs daily.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I test in the evening and add bleach right after when the sun is off the pool. 😎
    Jeff
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    I test right when I wake up in the morning (at about 8), then in the evening. I do this so I can measure the chlorine loss more precisely. Once I get used to the daily chlorine loss, I will just pour the estimated amount of chlorine in, and then test at the end of the week. I also add liquid chlorine after the sun goes down. I don't run my pump at night, so I usually just evenly distribute it around the pool, and sometimes brush the walls.
    Bobby (my pool)
    18,000 gallon in ground/white plaster
    Flotec pump/Aquatech MYB100 single cartridge filter - runs 6 hours/day in evening during summer
    38,275
    So many things wrong with that post thinkpad ... tsk tsk
    Only testing weekly?
    Not pouring the bleach in front of a return jet?
    These are not recommended actions for new members
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Well, I haven't gotten to the point of testing weekly. I was going to start once I got the hang of the daily chlorine loss. Do others not do this, also?
    Okay, I'm about convinced to run the pump in the evening. I'm about to go out right now to pour in chlorine, and I will change the timer.
    Bobby (my pool)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Best time to test?
    ThinkPad, you need to get on a program ! I run my pump for 4 hours a night 90% of the time. My water is perfect ! 😎
    Jeff
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    I used to run my pump for 6 hours in the morning. I would pour bleach in in the evening when it's dark. Now I run my pump for 6 hours in the evening, and pour bleach in front of a return when it gets dark.
    pwrstrk, do you test daily? I thought it was pretty common to do only weekly testing after some experimenting. I guess I will continue daily before I pour in bleach.
    Just wait until the winter, that pump will be going for 1 or 2 hours daily.
    Bobby (my pool)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Best time to test?
    I don't test daily. Once or twice a week is good for me as I know my pool very well. If you tell anybody this I will deny it !!!
    After you get to be best friends with your pool and know its habits you can back off on the testing. 😎
    Jeff
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    I'll probably do FAS-DPD weekly, and OTO throughout the week.
    Just poured the chlorine in front of the most powerful return in the shallow end. My pool, Bobby, has two nipples in the deep end, and one standard return in the shallow, lol.
    But seriously, I like how the nipples push floating debris towards the shallow end, then powerful jet in the shallow end pushes the debris towards the skimmer. It was already like that when I moved in, I guess the person who adjusted everything knew what he/she was doing.
    Bobby (my pool)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by pwrstrk View Post
    This for me too and I time it sometime during my evening 4hr pump time. If I'm out for the evening, then during early morning manual start pump or midday 2 hr pump cycle.
    Isolated Spa - 345 Gallons
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    I ran my pump from 6pm to 6 am and test around 7 or 8 pm after the water has mixed in. Clear pool so far!
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    Jul 2014
    Crowley,Louisiana
    26
    So 30 min. After pump is on. Is that with or without salt generator on? And I guess being covered alot doesn't hurt or affect anything then?
