Results 1 to 8 of 8
Thread: Blower & Lights
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Blower & Lights
    I was told that these were for my blower & spa & pool light, my question is I found a ground wire unattached would it be to this or to my pool cage, I was told by PB cage, but there is a grounding lug on the unit with no wire on it. Thanks
    Sent from my SCH-I535 using Tapatalk
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    38,524
    Re: Blower & Lights
    That is a bond wire and should be attached to a lot of stuff around the pool, including all the equipment, the rebar in the shell, the deck slap, any metal like that apparent black fence (?), etc.
    Odd that one end just stops there. If there is a bonding lug, then I would think you would want to attach it.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Blower & Lights
    Yes everything on the slab is bonded, I will connect it to the unit, it goes into the ground...
    Thanks
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Blower & Lights
    I just noticed that my heat pump was not bonded, there is a lug for one, I attached the bond wire to it, that should be bonded correct? Thanks
    Autopilot SWG
    38,524
    Re: Blower & Lights
    Yup
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Blower & Lights
    I have two lights spa & pool, but I only see one bond wire on one of them, they are both turned on together, does the other one have to have one also? Thanks
    Autopilot SWG
    38,524
    Re: Blower & Lights
    Likely they are bonded at the fixture themselves. But adding more does not hurt anything.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Blower & Lights
    Thank you
    Autopilot SWG
