Results 1 to 9 of 9
Thread: My Salt Pool salt cell protector
    Jul 2014
    St. Simons Island, GA
    172
    On the shelf at Wal-Mart I found a product called "salt cell protector" under the brand name "My Salt Pool." The label does not list the ingredients. Mysaltpool.com does not list the ingredients either. Does anyone know what is inside this bottle? It's a 1 quart bottle and claims to treat 10,000 gallons at start up or 1/2 a quart once a month for maintenance. The label and the website claim that it prevents build up of scale on electrolytic cell.
    Home pool: Intex 11,400 gallon AG vinyl pool with sand filter & SWG. Taylor K-2006 test kit - coastal Georgia. I'm also in charge of the Elk's Lodge Pool, which is 55,000 gallons in-ground concrete with sand filter, 2 HP Hayward pump, currently using tri-chlor pucks and cal-hypo system.
    38,524
    Re: My Salt Pool salt cell protector
    If they will not tell you what is in it, why would you want to add it to your pool?
    Could be some kind of borate product.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    http://www.menards.com/msds/112430_001.pdf
    Sounds nasty. I wouldn't want to swim in it.
    Jul 2014
    172
    That hazardous material fact sheet says it has "etidronic acid" and "2-Butenedioic acid (2Z)-, homopolymer", both at 10%-30% weight percent.
    Any clue what those are?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Mar 2014
    Las Vegas
    288
    I agree with bobodaclown. Pool snake oil. It won't be going in my pool.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Richard320's Avatar
    Jan 2010
    19,073
    Snake Oil has different packaging.
    38,524
    Apr 2011
    Murrieta, CA
    2,360
    That's respectable "snakeoil", they tell you what it is! I can appreciate that, I hate the hidden snakeoil and hidden (actually found) snakes. LOL
