Results 1 to 12 of 12
Thread: Pool Filter Sizing help
    May 2014
    New Jersey
    30
    Guys,
    I think my sand filter is not working like it should and I'm looking at replacing it.
    I have 2 options so far:
    Hayward CC15093S Xstream 150-Square-Foot Cartridge Filter and 1-1/2 Horsepower PowerFlo Matrix Pump
    Haywood DE EC50 Filter and 1 1/2 Horsepower Pump
    Can anyone tell me if any of those will work for my Morada 24' 52" AG pool?
    Rocky
    13,500 Gallon 24' x 52" AGP
    Hayward DE EC50 w/1.5HP Pump
    Taylor K-1004 Test Kit
    Intek 2014 SWG - Copper Disconnected
    38,475
    Re: Pool Filter Sizing help
    Well for a 13,500 pool, I would suggest a 200+ sqft cartrdige or that bump DE should be fine. Although with your shorter season, you could likely go smaller on the filter.
    For the pump, a 1HP 2-speed is what I would recommend. Often the combo packages are not the best options.
    What exactly is your problem? Is it the filter or the pump that is not working?
    May 2014
    New Jersey
    30
    Well, my pool has turned green after the rain 4 days ago,was clear and readings were:
    Fc 5
    cya 40
    Al 110
    Ph 7.8, was adding ph minus before the rains
    It turned cloudy green immediately after the rains. The only noticeable difference was that ph went up to 8.
    I shocked it to prevent algea and have kept it high since, but it's not clearing, eventhough I'm running the filter 24hrs.
    I suspect the filter to be the cause.
    38,475
    Green cloudy water is nearly always a chemical issue and not a pump or filter issue.
    You need to follow the ShockLevelAndMAINTAIN Process to clear up the pool and then the filter should be able to clean out the dead stuff. BTW, a FC of 5ppm is not high if that is what you are implying. The shock level for a CYA of 40ppm requires a maintained 16ppm of FC.
    May 2014
    New Jersey
    30
    5ppm was the level before it rained, when the water was nice and clear.
    38,475
    That was 4 days ago ... did the FC level drop? What did you "shock" it to?
    Again, you need to follow the SLAM process and not a one time hit of some powder.
    May 2014
    New Jersey
    30
    I've been maintaining it between 16-20 since and it's not budging. The water isn't even getting cloudy like it should.
    38,475
    Why should the water get cloudy? If it is clear, why suspect a problem with the filter?
    When did you raise the FC up to 16ppm?
    First you said the pool was green and cloudy and now you say it is not as cloudy as you expected ...
    I guess I am not understanding ... what does the water look like now?
    May 2014
    New Jersey
    30
    Lol, ok let me clarify.
    Before the rain, the pool was clear and levels were good with one exception, ph was a tad high.
    After the rain, pool turned cloudy green and ph went up even further.
    I immediately shocked and have been maintaining shock level for 4 days now, but haven't noticed any changes.
    I'll report back tomorrow.
    Oct 2012
    Houston, TX
    186
    The Taylor K-1004 is not FAS-DPD so is not able to test FC values high enough to know whether you are at shock level or not, so not only will you not know your shock level, you wont be able to perform an OFCL test which is a requirement for knowing you have successfully completed the SLAM. . It also won't test CC as well. In order to SLAM correctly you need to test accurately and frequently, particularly in the beginning. Hourly if possible, twice daily absolute minimum.
    Click the test kit link in jblizzle's signature for info. Also read and thoroughly comprehend the SLAM link and associated OFCL info he referenced above.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    May 2014
    New Jersey
    30
    Hey guys, thanks for the advice. I know I need to get the better testkit, but I had bought that one before finding this forum, so I'm stuck until I get the funds.
    I treated with green to blue lastnight and attached are the results.
    Stuff settled on the bottom.
    Will vacuum to waste.
    38,475
    We do not recommend or use those type of magic potions ... so can not offer advice.
    If adequate FC was maintained for the SLAM process, then you should have been seeing improvement.
