Thread: Will Intex Sand Filter work with 10ft Metal Frame ?
    MrsDimples's Avatar
    Jun 2014
    England
    47
    Does anyone know if Intex Krystal Clear Sand Filter and Pump 1,050gal/hr #28646
    http://www.amazon.co.uk/Intex-Krysta.../dp/B005DUW65O
    will work / fit with an Intext 10ft Metal Frame, (not Ultra), pool?
    Thanks in advance.
    Intex 10ft Metal Frame - 1,185 gallons
    Intex 530 gall. per hour Filter Pump (Model No. 58604) - Cartridge
    Chlorine / pH dip sticks
    Intex 3kw Heater
    MrsDimples's Avatar
    Jun 2014
    England
    47
    Re: Will Intex Sand Filter work with 10ft Metal Frame ?
    To clarify, the 10ft pool has 32mm hose & the Sand Filter 38mm.
    Is there anyway of making the two compatible?
    Intex 3kw Heater
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    The Intex adapter B is supposed to convert 32mm to 38mm. In the US they are marketed as 1.25" to 1.5" . I don't know if they would be the same size in the UK or not, but a google search showed several vendors selling them on ebay UK.
    Love TFP? Become a
    TFP Supporter!
    MrsDimples's Avatar
    Jun 2014
    England
    47
    Perfect.
    Thanks a lot Zea3.
    Just had a look & the company we bought the 10ft pool off, sell them.
    Intex 3kw Heater
    Jul 2009
    Houston, Texas
    9,377
    You are welcome! Have fun with your pool!
    Love TFP? Become a
    TFP Supporter!
    Oct 2012
    Houston, TX
    186
    In the US it comes with the adapter B in the box. However, most people cut the holes in the pool to make them larger. The increased hole size is still within the reinforced vinyl area. The larger fittings give better flow.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
