Thread: Finding exact quantity of water.
    Mar 2012
    Maryland
    87
    So I have a 24' round 4' deep pool. however, I notice the pool floor is not completely flat. It actually gets deeper as you get towards the center. I've always been doing the calculation based that I have 13,500 gallons. But I know it's more than that.
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Finding exact quantity of water.
    I suggest you keep close track of what you test and what you add and what effect it has. Compare your results to Effects of Adding Chemicals in poolmath.
    If you consistently undershoot, increase the pool volume in poolmath until things align. The pool volume is constantly changing anyway, with evaporation and refilling and so on, but over a period of a few weeks, you will hit the magic number where no matter what you add, it behaves exactly the way it's supposed to. Use that as your volume.
    Jul 2014
    Hope Mills, NC
    567
    Use depth as halfway between wall and center. if you have 4 feet at the walls and 4 1/2 feet at the center, use 4 1/4 feet as your depth.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    38,371
    As Richard basically said ... there is no reason to be exact. Just see how well you are hitting the chemical target and adjust as needed.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Divin Dave,
