Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Cyanuric
    Robert.wolfe's Avatar
    Jul 2014
    Dallas, tx
    25
    Cyanuric
    Alright I've been working for a pool company for over a year. I question about cyanuric. I know what it does some what. But the part I don't know is. If the cyanuric acid is 100+ but my chemistry is at 5- 7.2/7.6- 80-100. Will I have algae start to grow.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Cyanuric
    Hi, welcome to TFP! Just to clarify, are you saying your current levels are FC 5, pH 7.2-7.6, CYA 80-100?
    Love TFP? Become a
    TFP Supporter!
    38,279
    Re: Cyanuric
    Welcome to TFP!!!
    I have no idea what all those numbers are ... care to elaborate?
    If your FC is lower than the minimum listed in the FC/CYA Chart, then you are at risk for algae starting as well as disease transmission.
    Jul 2014
    Dallas, tx
    25
    Re: Cyanuric
    No my alkalinity is 80-100
    Jul 2014
    Dallas, tx
    25
    Re: Cyanuric
    5 on chlorine 7.2-7.6 on pH and 80-100 on alkalinity
    38,279
    Re: Cyanuric
    5 is < than 7 which is minimum for a CYA of 100ppm ... so yes, you are at risk. {Of course there are special circumstances in which you may be lucky and not have algae grow, but still be at risk for disease transmission}
    But, given those results, I have to guess that you are using test strips which we do not trust as being reliable or accurate.
    Jul 2014
    Dallas, tx
    25
    Jul 2014
    Dallas, tx
    25
    Re: Cyanuric
    No I use a Taylor test kit
    38,279
    Re: Cyanuric
    What chlorine test?
    Jul 2014
    Dallas, tx
    25
    Jul 2014
    Dallas, tx
    25
    Re: Cyanuric
    It test up at 5 actually little dark but I can only go up to 5
    38,279
    Re: Cyanuric
    Not good enough ... you need the FAS-DPD chlorine test as your pink DPD color matching test is limited to 5ppm and will actually have the color fade out at high FC levels.
    Please clear something up.
    Is this your pool? Or do you work for a company that maintains other pools?
    Jul 2009
    Houston, Texas
    9,379
    Re: Cyanuric
    Without knowing the CYA level we cannot tell you if you have enough chlorine to sanitize the water and prevent algae from growing. The CYA test tops out at 100. If you have a test that showed 100 CYA the real result may be much higher. When you get a result that high you should dilute the sample by mixing one part pool water to one part tap water and run the test again. Your result will be double what is shown on the test vial.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Cyanuric
    There's no guarantee you'll get algae, but you have increased the risk. If there's no algae food, it won't grow. If there's no algae spores, it won't grow. You never see algae in a sealed bottle of distilled water and it has no chlorine in it. But since most pools are not hermetically sealed, algae is a constant risk. For 100 CYA, maintaining a minimum of 7 FC will almost guarantee you won't get algae, as certain as it's possible to be. http://www.troublefreepool.com/conte...art-slam-shock
    Jul 2014
    Dallas, tx
    25
    Re: Cyanuric
    I work for a company. I've drained 1 pool I take care of cya is at 50 and my readings are 5 7.4 and 90 and I no longer have any algae issue
    Richard320's Avatar
    Jan 2010
    18,995
    Re: Cyanuric
    Quote Originally Posted by robert.wolfe34 View Post
    5 FC is well above minimum for 50 CYA. http://www.troublefreepool.com/conte...art-slam-shock
    38,279
    Re: Cyanuric
    Well, the minimum for a 50ppm CYA is 4ppm. So if it stays above that, then you should be fine.
    How do you guys chlorinate? How often do you visit?
    The methods we teach here are geared toward the homeowners that can spend a few minutes on the pool everyday.
    Jul 2014
    Dallas, tx
    25
    Re: Cyanuric
    I visit pools weekly. 10-12 pools a day.
    Jul 2014
    Dallas, tx
    25
    Re: Cyanuric
    We use granules. Calcium hypochlorite
  20. Back To Top    #20
    Jul 2014
    Dallas, tx
    25
    Re: Cyanuric
    I'm looking for ways to get more knowledge of my pools. The service guys are to busy to stop and worry about my pools. I clean the same 55 pools a week.
