Thread: Is it safe to mix test water/Regents?
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Question Is it safe to mix test water/Regents?
    I have gotten into a routine of using a sports bottle to collect sample water, perform the tests and dumping the samples into a Tupperware bowl.
    Is mixing the water and regents a bad thing?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    May 2014
    Ft. Wright, KY
    44
    Re: Is it safe to mix test water/Regents?
    I hope not, cause that's what I do. Haven't had an explosion yet! Get some pretty colors, though.
    24K gallon IG gunite (built 1976), plaster (Diamond Brite) redone (poorly) 2012
    Hayward EC65A DE filter Taylor K2006-C test kit
    Ft. Wright, KY (Cincinnati area)
    Don't argue. Just get the kit. TF100 or Taylor K2006C
