Thread: Liquid vs granular cyanuric acid (i.e stabilizer.)
    I'm curious to hear opinions on the traditional granular CYA vs the liquid "instant" form (i.e. monosodium cyanurate monohydrate.) I know that the liquid is much more expensive per ppm raised, but I only need to bump up my CYA a bit, so the cost difference is no big deal in my case. Given this, is there ANY reason not to use the liquid form? It seems like the liquid would be faster and easier to administer, but I'm wondering about other chemical effects that might take place by using monosodium cyanurate monohydrate, and if there are any special considerations I should take into account.
    Larry
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I don't know of any reason's not to use it. The majority of people use the granular for the reason you stated, price.
    If you could add all your pool, equipment and your location to your sig, that will help us help you better. 😎
    Jeff
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Liquid vs granular cyanuric acid (i.e stabilizer.)
    No reason not to use liquid. I never have used liquid myself because granular is cheaper. One negative of granular (if you want to call it a negative) is that it can take up to week to show up on your CYA test. If price is not a concern for you, there's no reason not to use liquid.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I've used the liquid once when I wanted to know immediately a confirmed cya rate (and had zero) against which to shock. In terms of cost, my reasoning was that I'd save as much in reduced chlorine required for same
    Now that the swamp is recovered and I only need a little to bring it up from splash out, etc., the slower powder is just fine too...because I haven't had to shock since that first time
    So its just a matter of preference.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Cost is the driving factor. Really in the big scheme of things waiting for 24 hour or so for it to dissolve isn't a big deal.
    Here's some other reading:
    http://www.troublefreepool.com/threa...itioner-dosage
