Thread: intex sand filter backwash problem
    Jul 2014
    TEL AVIV
    1
    hi
    i have intex pool that comes with sand filter.
    yesterday i wandted to do backwashing.
    i shut off the pump, and put the valve to backwashing.
    then water automatically started run threw the waste hose while the pump is still OFF.
    i know that i should put the pump ON and then water need to run threw the waste hose.
    what im doing wrong ?
    tnx!
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: intex sand filter backwash problem
    Nothing. Some water always spills out of my waste line when I switch to waste with the pump off. And if your backwash hose is located lower than the waste outlet, gravity feed acts as a siphon.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    This behavior is by design. Mine does it as well.
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
