Thread: Evaporation question
    I just completed a new pool. Its about a month old and I have issues with water evaporating or a leak. I haven't tried the bucket test but will do it tomorrow. Whats normal evaporation in the dfw area. Mine is ranging to about 2 inches a week. Thanks.
    Using Tapatalk
    Re: Evaporation question
    2 inches a week isn't excessive here this time of year. Do the bucket test; that's the only way to know for sure.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    2 inch a week isnt unheard of. Especially if you get a lot of direct sunlight all day.
    Ive lost almost an inch since saturaday with prolly only get about 5 or 6 hrs direct sunlight on the pool each day.
    Quote Originally Posted by jedij007 View Post
    Divin Dave,
    Jun 2013
    East TN
    309
    I was worried about mine. I did the bucket test last night and lost 1/8" through evaporation over the night. I didnt think I would loose that much at night but I did.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
