Results 1 to 7 of 7
Thread: Chlorine %
    Jul 2014
    albuquerque
    15
    Chlorine %
    I am having a hard time figuring out the % of my chlorine. I think the Clorox I get at the big box store is 8.25%......is this right? Is this good? Where can I get 12% ?
    20 X 40.....32000 Gallons.....Gunite.....Live in Albuquerque New Mexico...............Sand Star Pump...Heater but only use when we first start up in April/May...
    Fort Worth, TX
    83
    Re: Chlorine %
    The % of chlorine is noted on the label. You don't have to guess.
    I'll let someone else answer the 12% question.
    I see 10% at Ace Hardware, Home Depot and Lowes.
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Chlorine %
    All liquid chlorine should list the % on the label in the ingredient list.
    We use 10% but most pool stores will carry 12%. Check the date on the bottles as well.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Chlorine %
    Just have to search around for the best price and sales and then stock up. I get 12.5% from TheGreatEscape at $2.50 a gallon in the Chicago area. Menards also has sales every once in a while buy one get one free which equates to $2.00 per gallon of 12.5%.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Chlorine %
    One thing I want to mention about the 12.5% is it degrades in its percentage the quickest. If you use it check the FC level 30 minutes after you dose with it and see if the FC level is where pool math said it would take it to.
    I've used 12.5% that was a month old and it didn't raise FC to the level it should have. It was more like 10% chlorine.
    Just something to think about. 😎
    Jeff
    Jul 2014
    albuquerque
    15
    Re: Chlorine %
    Thank you everyone for your help
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Chlorine %
    The liquid chlorine I got at Walmart this year had 13% marked on it.
