Thread: Intex Krystal Clear Saltwater System CS8110 Low-salt but salt test HI
    Intex pump flashing low-salt. Crazy thing is I have over the amount of salt recommended for my pool. It's an Intex 22 X 52 (10,000 gallons). Please see the attached pic for the Leslie pool test they gave me today. HELP!!
    This lo-salt indicator is driving me crazy.
    I have cleaned with vinegar.
    The pool water must be out of balance because it is cloudy as well.
    Thanks Guys
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Re: Intex Krystal Clear Saltwater System CS8110 Low-salt but salt test HI
    How old is your SWG? The cells in them don't last forever. My experience has been that they have to be replaced about every 3 years. When mine have failed in the past, they also indicated low salt.
    You can order a replacement cell directly from Intex.
    If your SWG is new, then I would suspect either a faulty unit or the salt reading from Leslie's may be in doubt. Buy some salt test strips and read it yourself and see what result you get.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Thanks Jeff. Do you have a intex part number per chance? Don't see one at all on Intex website. Thank you.
    Your CYA is zero, at least according to Leslie's. With CYA at zero you will lose all of your chlorine to sunlight each day. With a SWG we recommend CYA be between 70 and 80. That doesn't explain the low salt light, but it does explain why FC is zero and the water is getting cloudy.
    If the SWG is new and the cell plates are clean I would suspect the salt test result and trust the SWG instead. If it is more than one year old and the cell plates are clean, I would trust the salt test and replace the cell. If there are any white deposits on the cell plates, that is the problem and the plates need more cleaning.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    How much does pH affect the efficiency of the SWG's?
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Quote Originally Posted by shultzeej View Post
    No, I don't see it either. IIRC, I called them to get a replacement last time. I want to say I paid around $60 for it.
    Pentair IC40 SWG
