Results 1 to 7 of 7
Thread: My poor TigerShark.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    My poor TigerShark.
    Well the possible but not likely happened. I have small thermometers hanging into my pool. They're about 3/4" diameter tube shaped types. Turns out, when my TigerShark climbs the wall, they will eventually get stuck in just the wrong place: between the brush roller and the body of the cleaner.
    My cleaner hung there for likely hours, helplessly churning on the thermometer, wreaking havoc on the roller. I was too mortified to think about snapping a useful photo... Several ball bearings on the bottom of the pool confirmed my fears. One of the roller bearings was broken, leaving the contents on the pool floor.
    Took the robot apart and here's the aftermath:
    Hopefully a replacement bearing will be all it needs. Let this be a lesson. Lift those thermometers out when starting your robots.
    Isolated Spa - 345 Gallons
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: My poor TigerShark.
    As wonderful as pool robots and auto cleaners are, I don't run mine when I'm not there to check on it every so often. My Ranger used to climb walls and start sucking air, or get caught on the stairs. I hope yours is not too difficult to fix.
    Love TFP? Become a
    TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    What a bummer.
    I never even thought about my robot eating my thermometer. I just made sure that never happens. The thermometer is officially retired. (dont need it anyway...its either too cold to swim or it aint! )
    Divin Dave,
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I just had the same thing happen to me with my AB 4WD.
    I found it molesting my floating Duck thermometer and got the string sucked up into its gears.
    After cutting the string and working it out of the gears it seems I stopped the offense it in time.
    The duck no longer lives in the pool and now if I want to know the temp I put it in for a couple of minutes
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    You probally have this info but if you don't hope it helps:
    http://www.inyopools.com/HowToPage/h...rive_belt.aspx
    Parts:
    http://www.inyopools.com/pool_parts_...ger_shark.aspx
    Hope that helps.
    Feb 2014
    Central Minnesota
    5,080
    Yeah. Love that inyopools.com has illustrated part breakdowns and instructions for repairs! Thanks for the reminder.
    Feb 2014
    Central Minnesota
    5,080
    New bearing and TigerShark is back (with thermometers out of the pool).
    My supervisor approves.
