Thread: algae problem, pool store water testing numbers, waiting for kit to arrive
    Apr 2014
    Fresno, CA
    23
    I decided to start a new thread on this in the right forum. So we have algae. We have been using pucks and a very basic chlorine and pH kit, and very occasionally we put in some loose dichlor if the chlorine is a bit low. This approach was fine the first year. This year, we've had some algae, and I'm learning about this forum's method of pool care. I ordered a "good kit" and am planning to use bleach rather than pucks (unless we go out of town).
    Here are the numbers I got when I brought our water to the pool store to be tested. I'm not sure whether to trust these numbers, but it will be some more days until the testing kit arrives. It's supposed to be here by August 5, but it's hard to wait that long. I'd like to get this under control in the meantime, but that's hard to do without proper testing, I guess. So, what would you do in this situation, while waiting for the kit?
    Free available chlorine 4.0
    Total available chlorine 4.0
    CH 150
    CYA 60
    TA 80
    pH 7.3
    Phosphates 400
    These were the numbers from the pool store testing yesterday. I'm not sure what's the best thing to do until I get the test kit and can do the SLAM method. What do you think I should do to keep the chlorine up and the algae at bay, until we can really measure and treat this more systematically? Fortunately we don't have any swim parties coming up (we had one in June and two in July) but it's been over 100 degrees day after day, and I'd really love to be able to use the pool!!! Thanks.
    ~13,000 gallon in-ground plaster pool, built in late 80s, refinished in fiberglass in 2013
    Pentair IntelliFlo 3HP Variable Speed Pump, 2014
    Old HP booster that runs a Polaris 280 sweep, ages unknown
    Old DE Filter, age unknown
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: algae problem, pool store water testing numbers, waiting for kit to arrive
    PM sent
    Divin Dave,
