Thread: pH adjustment - Citric Acid
    Jul 2014
    Blenheim
    3
    Hi all,
    I am new to this site and am looking for some expertise from anyone who may be able to shed some light...
    The current local swimming pool uses sodium hypochlorite and UV for its main sanitisation however the incoming water supply is between 8 and 8.5 pH.
    Can anyone see an issue with using citric acid as a pH decrease chemical?
    Will it react with any other chemicals or create a build up over time?
    Thanks!
    38,546
    Re: pH adjustment - Citric Acid
    Welcome to TFP!!!
    Citric acid reacts with and mutually destroys chlorine. It is usually best to use muriatic acid for lowering the pH.
    Please add the state to your location in your profile and pool details to your signature as described HERE as it will help us help you in the future.
    Jul 2014
    Blenheim
    3
    Thank you...
    The local pool really does not want to use muriatic acid or CO2. Is there any other safe method?
    Jul 2014
    Blenheim
    3
    Thanks, Is there a liquid from of sodium bisulfate? Whatis the best way to add this?
    38,546
    The build up of sulfates is also not good and generally that is not the best product to use. Plus I think it is usually solid and must then be pre-dissolved and added to the pool.
    Muriatic acid is the best product.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    I suggest you look a few posts down and follow the links in this thread.
