Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Storing Solar Cover Suggestions
    ddpool's Avatar
    Jul 2008
    Minnesota
    61
    I was wondering if anyone could share how they dry out the solar cover of a big AGP. We have a 24' and I was just pondering how I would approach trying to dry out and store our solar cover.
    Any good tips on getting the solar cover dry before rolling up to store?
    Thanks
    Coming Soon: In-Ground
    Previous: 24' Round AGP, 2HP Pump, Sand Filter, Solar Cover
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Storing Solar Cover Suggestions
    BTW, I love your new avatar! hehehehe
    No matter how well I tried to dry mine, there was always water left over, and thus a bit of scummy stuff to contend with. You will likely have to spread it out on the driveway to clean it off in the Spring. One year it was bad, so I cleaned it with tide and a brush real good. That was just plain stupid and I made the situtation worse. Do you have any idea how long it took to get rid of all the soapy bubbles? Live and learn.
    I have laid mine on the grass (mistake, killed the grass) and I have draped it over the side of the deck. I see my neighbors lay theirs in the driveway to dry, if your's is big enough. That's what I plan to do this year.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by frustratedpoolmom
    That's exactly what I do with mine (24 ft). On a sunny day, it takes about 30 minutes to dry. Then it's just a matter of folding it up and putting it away. It gets a little dirty from the driveway, but that can be hosed off next time I get it out.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Aug 2007
    Surrey England
    30
    I used to anchor mine to the top of the garage flat roof, using bricks - that way I could scrub it clean with a broom. Now I hang it over two lines between the garage and the house. However, I only do that at the end of the season. I wasnt sure what would work best for daily use so I attached a bike hook on the garden fence one end of the pool and a corded tape the other end. The bike hook is the most convenient and it moves sideways when not in use (to avoid children running into it). I intend to replace the tape with another bike hook - next year, when I buy a skimmer, and perhaps some decking?
    Oval 18'x12' Quick Up Pool. 16" Sandfilter. FSP400 3/4hp pump. Duratech3 heat exchange pump.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    At the end of the year to make sure ours is fully dry, we lay it out over a bunch of lawn chairs. We also do this with our Intex pool in the fall to dry it out so we can fold it up for winter.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    What about if you live in a hot sun area, like here in Texas? I grew up in Minnesota, and never imagined the sun could be so blistering hot. We will not need to dry out our solar cover until October, but the sun will still burn at that point. I read on the solar cover instructions to be careful about putting it out in the hot sun when it is not in water. But we will not have a shady place to put it to dry by October- leaves already coming down from drought. I could put it on the driveway after the sun goes down on the other side of the house, but the drive is not big enough for our 28 foot cover. What do southern pool owners do, and is the solar cover really that fragile?
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    Dec 2007
    Central New York
    504
    I still throw mine away at the end of each season. Get a nice new one in the spring.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    You can set it out in the sun. You'll just have to watch it and when it's dry fold it up right away. The reason you don't want it in the sun too long is because without the water to keep it cool it will get hot and possible burst the little bubbles.
    HTH,
    Adam
    I hit mine with the leaf blower to speed up the drying time.
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Leaf Blower!! Excellent idea. Thank you.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    I have cut mine into four sections and then re attached with cable ties or zip ties. This way I can keep it together in sectins for easy removal from the pool. When it comes to storing it this winter I will then cut the cable ties from the middle section and have two pieces...I can then place it on driveway to dry...and then fold into two neat little bundles to put back in the box it came in once it is dry. I will then store in an appropriate place alone with my other pool equipment. This system has worked well for both putting the cover on the pool and taking it out. I have gotten less debris in the pool by doing it thsi way.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Cubbybeave, do you have a picture that you can post of how you cut up and tied up the solar cover? Mine is 28 ft diameter, still in one piece, and a massive pain. I would appreciate a view of your approach.
    11,969
    Quote Originally Posted by amjohn
    Here's a pic of Beave's solar cover:
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Is there some sort of washer/grommet/tape that the wire tie passes through to keep the cover from shredding - they are very sharp? I finally had it and cut my cover into three long pieces last night- hope I am not sorry. It seems to be staying on the pool similar to how it did before as one piece and is a lot easier to remove and replace. If high winds blow it around, I will try the wire tie method. Thanks for the pic.
    11,969
    I think he used duct tape or gorilla tape, is "gorilla tape" an actual product or did I just make that up.... I seem to recall hearing the term.
    Feb 2008
    Northwest Indiana
    900
    amjohn...Just used doubled up duct tape and used a paper punch to punch the hole through the tape and the cover. I am not sure how long the duct tape will last. but it was a quick fix. I cut my blanket in fourths thinking it would be easier to put in the pool by myself...it wasn't...I don't have a deck yet so I have to get in the pool and spread it out...two person job. This way i can fold the outsides in on the middle sections then fold those sections on themselves, and then wrap it up in a neat little package and carry up the ladder byself dump it in and then unfold in the pool...It took me about 10 minutes from start to finish the other night.
    Beave
    Feb 2008
    Northwest Indiana
    900
    Thanks Ann!!!
    Beave
    Feb 2008
    Northwest Indiana
    900
    These are not wire ties...They are plastic zip ties or cable ties...I got mine at walgreens...Box of one hundred cost about $4...They come in various sizes but I used the smallest size so there was not a lot of the tag end left over...Be sure to punch your holes on the outer edges in far enough on the cover that there is no way for the zip tie to rub agains your liner. They are quite rigid and could do some damage...my outer edges are in atleast two inches from the outer edge.
    Beave
    Beave
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Thanks beave- sorry about the term "wire tie". I know what you mean though- zip ties. We use in the aircraft industry to bind wire bundles into harnesses as they travel through the aircraft, so it is habit for me to call them wire ties- distinguishes from cables used to fasten other things together.
    So far, my three pieces of solar cover are working well. I do not have a deck yet either (some day, some day) and use a solar saddle, so I push my solar cover over the edge of the pool into the saddle. The big cover as one piece was too much for me to manage alone, so this is doable with it cut into three long strips -of course a 28 foot long piece of bubble wrap is still a lot of bubble wrap. If I get really lazy, I push over the middle strip that covers the diameter of my round pool and just create a 28 foot long swim lane.
    And it will definitely be easier to dry out and put away for the winter- still like the leaf blower idea.
  20. Back To Top    #20
    Feb 2008
    Northwest Indiana
    900
    Not a problem I know them as cable ties...My brother in law used to be an engineer for one of the company that makes them...That is what they call them...I am glad that it is working well for you...I still have a little problem getting it out by myself...but I am not too worried about that I was more worried about getting it put on by myself...A deck is so much easier to utilize...
    Beave
