Thread: Leaky Hayward Filter - Do I need a new O-ring?
    May 2014
    United States
    3
    Hey everyone,
    I have been noticing a stream of water running from my Hayward SP71 sand filter, and I wanted to find out if it's a leaky O-ring or something more serious. I took a picture of the situation:
    http://imgur.com/6ZdfQVu
    If it does need a new O-ring, can I simply turn the pump off, unscrew the two bolts to remove the collar and replace the O-ring (with plumbers silicon lube)? Thanks for the help!
    Cig_arello's Avatar
    Apr 2014
    Eastern OH border town
    22
    Re: Leaky Hayward Filter - Do I need a new O-ring?
    Looks like it is coming from the head ring on top with the water trail. I just replaced my spider gasket an head O ring for $15. Amazon has multiple low cost sources from complete sets to individual gaskets. Only took 10 minutes to do too.
    18x36 IGVL 36,000 gallons 10.5' on the dive, 1 hp Hayward self priming super pump, 300 lbs sand filter w/ Hayward Vari-Flo valve
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Like Cig said, there appears to be some dried trails coming from the valve. Is it leaking at the valve top plate or below the valve at the top of the tank?
    If it's the valve, check the spider gasket. Likely replace.
    If it's the top of the filter, remove the valve, lightly lubricate the o-ring with silcone based lubricant and try to reseat it. Make sure when tightening the bolts, you get them both evenly just to snug. Then turn one side bolt one full turn, then the other one full turn. Alternate so it tightens equally until snug, not gorilla tight. Also, tapping on the sides of the collar every so often between bolt turns help keep the o-ring from sticking/rolling in the interface. If that doesn't work, replace the filter/valve o-ring. Pretty cheap as well on Amazon.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Quote Originally Posted by Inthedeepend View Post
    Hey everyone,
    Maybe, maybe not. Is it an above-ground pool? Water will seek its own level and come pouring out everywhere. We just don't know, because you haven't filled out your signature.
    Instructions on how to do this are here: Read Before You Post.
    You might also narrow down your location for us. Alaska and Hawaii are United States, and they are far different than the desert Southwest, the Great Plains, and the Gulf Coast. Recommendations can change depending on location.
    May 2014
    United States
    3
    Thanks for the responses.
    I think the leak is originating from around the black collar, not above where the white streaks are.
    When you say remove the valve, do I need to unhook the white pipes and remove the entire valve, or just take off the black collar and check the gasket?
    I'm in Missouri btw and it is an in ground 35k gallon vinyl pool
    Thanks again!
    Feb 2014
    Central Minnesota
    5,080
    Add the details of your pool to your signature as Richard has suggested. See above.
    I would try to remove the whole valve. However, as you may have noticed, this is rather difficult unless unions have been installed in the return and suction lines that go out from the valve. Such as this:
    If you do not have unions to disconnect you have two options. This is the problem of the top mount valve.
    1. Attempt to remove the collar and inspect/lubricate the o-ring as best you can and reseat. You may be able to slightly lift the valve enough to do so. You might not. You won't be able to replace the o-ring. Don't lift the valve very much at all as you could weaken the PVC joint strength.
    2. Do what should have been done when the valve was installed. Cut the PVC and install unions. Not overly difficult but can be intimidating if you haven't done it before. This will make it much easier to fully inspect and be able to replace the o-ring if needed and be very helpful in the future should another problem arise. Install them close to the valve so when the valve is removed using the unions, it's not too unwieldy.
    EDIT: Option 2 is the better option as these tank o-rings are known to develop leaks after only a few years of use and you'll be ready for next time.
