Results 1 to 12 of 12
Thread: Bought a house with a TFP already going!
    Jul 2014
    Radford, Virginia
    4
    Greetings all!
    I recently bought a house in Southwestern Virginia. I received a little instruction from the previous owner, and his parting words to me were," Just go to troublefreepools.com. Everything you need to know is there".
    Well, in the process of closing and moving in, the pool went untouched for 4-5 days and turned a nice shade of murky green. Fortunately he left me a TF-100 test kit, and I have been SLAMming away for 5 days. Initial readings were:
    FC, 0
    CC 1.0
    pH 7.5
    TA 100
    CYA 0
    Well, about 50 gal of bleach later, the green is gone, the water is still cloudy, and we have spent the last week trying to get some CYA to dissolve to give us at least some protection from the sun! Right now I am struggling to get the water clear. I added some DE to the filter to help.
    Is there anything else I can do?
    Thanks for all the help you have already been!
    Jim
    38,370
    Re: Bought a house with a TFP already going!
    Welcome to TFP!!!
    Please add your pool details to your signature as described HERE as it will help us help you in the future.
    With the information you have provided, it is hard to know if you have been SLAMing properly. What are the current FC and CC readings?
    May 2012
    Montville NJ
    545
    Welcome aboard!
    We need some particulars
    What are your test readings now
    What kind of pool is this
    What kind of filter set up are you running (I assume sand, since you said you added DE)
    What is the PSI on the filter.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jul 2014
    Radford, Virginia
    4
    I filled out my signature, but it doesn't appear...hmm.
    40k gal, in ground, vinyl liner. Hayward sand filter PSI 10 (I was told that this is 'normal' by the previous owner.)
    FC was 9 this AM. Sent it back up to 12. CC is unknown today. My daughter is doing the testing and didn't report it to me. I will run the full battery of tests when I get home.
    Oct 2013
    Chapin, SC
    1,141
    I made the mistake of not saving the first time I tried to do it.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jun 2014
    albany oregon
    15
    Was the pool just refilled? Seems odd that it would have no cya.
    16 by 48" 5000 gallons, AG, skimmer plus 1500 filter pump with gfci
    Mar 2011
    Houston, Texas
    413
    It also seems odd that with a SWG you went 4-5 days and got algae. I leave all the time for a week and I come back to a sparkling pool with 4-6 ppm of CL.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Jul 2014
    Radford, Virginia
    4
    No SWG. That is a project for next year.
    I thought that no CYA was odd too! But even after adding the reagent, a sample does not get cloudy. It is crystal clear! Pool math wants me to add 14lbs (!) of CYA to get the level to 30.
    The ladder is out and has been scrubbed...I even disassembled it and ran the steps through the dishwasher! I think I need to learn how to disassemble my light.
    Guess I forgot to save the signature the first time. oops
    40k gal, Inground, vinyl liner, Hayward Sand filter, approx 25yo (liner is about 3 years).
    Oct 2013
    Chapin, SC
    1,141
    No swg that I can see in his posts.
    Welcome!
    Very cool that the previous owner sent you here. You're on the right track with the SLAM; isn't it great to see progress? Just keep following the process and update us on your progress.
    On the CYA being gone, if the FC dropped to 0, it is possible that something (bacteria) converted the CYA to ammonia. The solution for the bacteria is to raise FC, which you've already done, and the solution for the ammonia is to SLAM, which you already have underway. So, if that was the problem, you've already properly addressed it. (For the gory details, see chem geek's thread here: http://www.troublefreepool.com/threa...CYA-gt-Ammonia.)
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Patience is key.
    When you backwash, did you replenish the DE?
    You are doing the right thing. Keep up the SLAM FC and keep filtering. It will come.
    Divin Dave,
    Jul 2014
    Radford, Virginia
    4
    Woke up this morning, FC had only dropped by .5 over night. CC is still 0, and I can see the skimmer lid I dropped into the deep end while vacuuming on Saturday!
    Yahtzee!!
    Thanks for all your help and encouragement
    Jim
