Thread: Help with wiring a new Hayward SWG from timer
    Apr 2014
    United States
    21
    I have added the wire to the timer for connecting to the SWG
    Green: I'm guessing this is groud
    White: When I touch this and the green wire I get 120 volts
    Black: When I touch this and the green wire I get 120 volts
    When I touch the White and Black with a voltmeter I get zero. Does this mean when I connect it to the SWG this configuration is a 240v or 120v?
    38,524
    Re: Help with wiring a new Hayward SWG from timer
    Something is not wired correctly. Where are these wires coming from? Can you add some pictures.
    White should not have power as it is usually the neutral for a 115V circuit ... unless if has been wrapped in tape to mark it as hot.
    And if you are measuring 0V between the white and black, that means they are the same phase and will not supply 230V.
    Something is not correct somewhere along the circuit(s).
    Apr 2014
    United States
    21
    There is a breaker right next to the timer. The wires are coming from that.
    Links to pictures are below ...
    http://picpaste.com/20140730_091429-FNpCFOxL.jpg
    http://picpaste.com/20140730_091444-KslsOxYH.jpg
    Apr 2014
    United States
    21
    Quote Originally Posted by vinjvinj View Post
    Figured it out. The wires were labeled wrong.
