Thread: Patchless patch
    Mar 2008
    Wake Forest, NC
    128
    Patchless patch
    Has anyone used this before? I have a leak that is not taking a patch very well and was hoping someone has had good results with this.
    http://www.inyopools.com/Products/00000016034836.htm
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Patchless patch
    How large is the leak? Sometimes you can just take an extra piece of liner and use it as a patch. Maybe check to see if the company who sold you the pool has a defective or sample liner that they could cut a piece from.
    I've never used EZ Patch's vinyl products however I can say that there plaster/tile products work well.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Mar 2008
    Wake Forest, NC
    128
    Re: Patchless patch
    Quote Originally Posted by JoshU
    I have liner from the build. It is a small hole. It is the location of the hole that is a problem. It is on the outside corner of a step on a seam. I patched it last year and it held well for the year. Started to leak just a bit this year so I pulled it and replaced. The problem is that I cant put pressure on the part that is leaking. If I could put a brick in towel on it I think it would be ok. I am thinking that the patchless stuff would be great it if was something I could ball up and then place on the hole and not have to put a brick on it.
