Thread: Balance which chemical first?
    Aug 2013
    Annapolis, Maryland
    5
    FC 3
    TC 3
    PH 7.9
    ALK 110
    CH 100
    CYA 20
    I need to reduce my PH and ALK and increase my CYA. Which one should I do first? Recommended numbers for a vinyl pool with SWG are CYA 70 - 80, PH 7.5, ALK 60 - 80. I use the SWG to maintain my FC but I use bleach to increase it or SLAM when necessary. I SLAM'd when the pool was opened because I had algae.
    18000 Gal Sport Pool with built-in steps. Vinyl liner. Goldline Aquarite SWG, Sand filter with Zeobrite, Hayward SP0712 Vari-flow, top mount valve. Newly purchased TF-100 test kit
    38,532
    Re: Balance which chemical first?
    Lower the pH and start the CYA dissolving ... these can be done as closely together as you can get to them. No delay required.
    Ignore the TA, it should balance out as you maintain the pH.
    Oct 2013
    Chapin, SC
    1,141
    Putting your location in your profile would be very helpful.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Aug 2013
    Annapolis, Maryland
    5
    Thank you for the info. I haven't put the chemicals in yet because I need to get my water level up so we can backwash first. We haven't had any rain in a couple of weeks. I have another issue now. My pool turned cloudy overnight and my FC and TC fell from 3 to 1.5. I'm assuming I have alga and need to SLAM it. Should I get the PH and CYA straight before I do this?
    Timerguy I'm in Maryland. I'll add that to my profile. I didn't realize it wasn't there.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Quote Originally Posted by regrolen View Post
    The pH needs to be fixed before you go crazy with the bleach. It's in the Shock Level And Maintain directions. It's your choice whether you raise CYA now or later. If you raise it now, stop at 30 CYA, then raise it the rest of the way after the SLAM is completed.
    38,532
    The pH and CYA did not make the water cloudy ... a lack of FC makes the water turn cloudy.
    But, with your low CYA and still having 1.5ppm of FC, the cloudiness is a little surprising.
    Certainly would not hurt to follow the SLAM process, but you need to lower the pH first.
