Thread: Cloudy Pool After algae treatment
    Jul 2014
    LaGrange, KY
    7
    Hi! We have had an above ground 30 foot pool for three seasons and have never had it turn green. Came home from vacay a few weeks ago and it was very green (green slimy steps, etc.) after lots of shock, Algaecide, balance paks, vacuuming, scrubbing and filter cleanings (we have a cartridge we always run 24/7) we now have a cloudy aquamarine colored pool. We added clarifier 36 hours ago and now the filter is finally green when we pull it out-it had been white even when we had algae. I don't have numbers, but have taken many trips to pool store and they say our numbers look good. I'm cleaning filter every 3 hours and vacuuming and created a central drain with hose and scrub brush. There is no longer green on the steps. I can't see bottom of pool yet though.
    What should we do?! This is new territory for us. Do I continue with clarifier? Get a new cartridge? Add flocculent and vacuum to waste? Wait? Thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cloudy Pool After algae treatment
    Welcome to TFP!
    The best thing to do is quit going to the pool store. They have you adding a lot of things you don't need. You need chlorine, chlorine and more chlorine. No balance packs, algaecides or clarifiers. Check out Defeating Algae for guidance on clearing the pool.
    Jul 2014
    LaGrange, KY
    7
    Thanks JohnT. I will read the info. We have shocked our pool several times! Our chlorine levels are high and continue to be. I am not sure if anything is still growing-I don't think there is. The pool is more blue than green at this point. I thought that shocking/slamming would lead to a milky white then clear pool with debris on the bottom. What could this change in color indicate? We have about two to three feet of visibility in a 48 inch pool. The walls and stairs are clean-not green or slimy.
    May 2013
    Fort Lauderdale, FL
    423
    Order a TF-100 test kit (or K-2006) NOW!
    Post the numbers
    In the mean time- read pool school (see my link)
    Stop adding expensive stuff from the pool store, right now you need nothing more than plain clorox. Start stocking up at the store.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
