Results 1 to 12 of 12
Thread: New Member/Questions
    MugZona's Avatar
    Jun 2014
    60
    Hi everyone!
    I'm a new pool owner (an 11,500 gallon IG pebble in case it doesn't show up in my signature) in Tucson, Ariz., and I've enjoyed lurking and reading lots and lots of threads over the last few weeks. You guys are amazing. Here's the story: previous owners relied on tabs and power powder. So here's what we have, after the overnight FC test, which I just completed:.
    FC: 10 (was 14.5 before bed)
    CC: .5 (.5 before bed0
    PH: 7.2 (yesterday, before I added a lot of bleach. this morning 7.5)
    CYA: 240 (used 1/3 pool water, 2/3 tap water and multiplied by 3 to arrive at this number)
    CH: 2100 (!) (fill water here is 70)
    TA: 140
    Here are some starting questions:
    1) I realize I need to drain and refill. Is the heat an issue with my pebble pool, or can I drain this anytime, day or night?
    2) Theoretically, could I operate this pool economically with such high CYA and CH levels if I managed to keep FC at a high baseline and kept PH down at 7.2?
    3) What should I do to clean the pool while it's emptying? Can I just refill right away? Overall, seems pretty clean, but I haven't seen this pool in its truly clean state.
    4) We get lots of evaporation here, so I've been adding water every few days (at least, I think it's evaporation). I guess this is one of the things that's making my CH so high, the other being the previous owner's liberal use of powder. Is this just something I'm going to have to live with?
    5) We have a jandy valve at the pool to control between Kreepy Krauly and skimmer (pool has a main drain but it seems to be inoperative; there's no diverter in the skimmer, just two empty holes). I cleaned the cartridges a few weeks ago, bringing the PSI in the filter down to 12, and now it's back up to about 20, and the Krauly is going slow or not at all (unless I really open the valve). Why doesn't the Krauly want to work is it just pressure related? I don't see debris in the Krauly mouth and regularly clean the skimmer/pump baskets.
    6) I notice that the filter pressure varies depending on how much I leave the Kreepy Krauly valve on vs. skimmer generally, it lowers a couple PSI when the Kreepy Krauly is really going at it, if I can get it to really go at it. Normal?
    7) Considering either an SWG or a liquidator, mainly for those times when I'm away. Any truth to the rumor that bees are attracted to SWG pools? Should I just rely on tabs for vacations (I don't travel that much) and keep an eye on CYA?
    8) In general, I'd like to rely on dry acid when needed, rather than muriatic, since we have a 1-year-old here and I'd rather work with the less hazardous material. Is that going to break the bank?
    Thanks! I'm sure I'll be back with more questions.
    P.S. I realize I asked too many questions. Just got excited. Sorry!
    13,000 Gallon IG Double Roman End with Steps PebbleTec Seafoam Green Pentair Clean & Clear Plus Cartridge Filter 320 1 HP Sta-rite pump (MPR6E-147L) TF-100 test kit Kreepy Krauly Cacuum
    MugZona's Avatar
    Jun 2014
    60
    Re: New Member/Questions
    Is my initial post showing up? When I click on it, nothing appears. A post I tried to make to replace it was deleted. Sorry to be so difficult on post #1...
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by MugZona View Post
    New members' first posts require moderator approval before they are visible in the forum. You should see it now.
    MugZona's Avatar
    Jun 2014
    60
    Thanks. Actually, the thread is here but the initial post seems to be empty (no text). Can we delete these and start over?
    SW Indiana
    9,199
    1) You don't want your plaster exposed to the sun anymore than you have to. You may want to look around and see if reverse osmosis pool filtering is available in your area. It may be an option.
    2) I don't see how you could operate at 2100ppm CH.
    3) Just get the water out and back in unless the pool has calcium scaling. Then you might want to investigate an acid wash to remove it.
    4) Maybe. A solar cover would help.
    5) Your cartridges are dirty. They may need replacing or acid soaking to remove calcium. Check with the cartridge manufacturer for soaking guidance.
    6) Normal.
    7) You'll probably have a better feel after you own the pool for a while, so I'd wait.
    8) Stick with the muriatic. Keep it in a bucket locked away from your child. Any pool chemical can be just as harmful to a young child as muriatic acid.
    SW Indiana
    9,199
    The post is there and complete. The second post was deleted as a duplicate. You may need to refresh your browser.
    MugZona's Avatar
    Jun 2014
    60
    Thanks, John!
    As far as draining, where do I send the water go from the submersible pump? The local water company says I can just let it drain anywhere, and didn't mention using the sewer cleanout. The groundwater level here in Tucson is around 300 feet underground, so am I right to assume draining will not be a problem re: hydrostatic pressure? Does anything change/become more dangerus for the pool if I drain the pool into the big wide open dirt space behind the house?
    Oct 2013
    Chapin, SC
    1,141
    Or---hook it up to a sprinkler and water your lawn. The only downside of emptying it on the dirt is you'll have the only mud bog in AZ.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    I don't see how you can avoid a partial (80% or better) drain. Just to maintain adequate FC at 240 CYA will mean the minimum FC is 18. That effectively makes the pH test useless, and with 2100 CH, you really need to know pH to prevent scaling.
    This thread will show you with pictures what happens to the pH test at high FC levels http://www.troublefreepool.com/threa...els-with-R-007
    MugZona's Avatar
    Jun 2014
    60
    OK — thanks very much.
    TeamNelson's Avatar
    Feb 2013
    Tucson (Marana) AZ
    48
    Not to get off point from your great questions (I'm getting a SWG & want bees answer too) -
    Welcome to TFP!!! You are gonna love it here & the great advice by everyone is priceless! We are learning so much too! The people here are so kind & SMART. Best of luck, now I'll but out & go back to learning & lurking
    12/2012; 16K Gal. IG PebbleTec, Pool w/Spa attached, Pump Sta-Rite IntelliPro 4speed VS 3050 160gpm, Cartridge Filters Sta-Rite S8M150 450SqFt, Pentair IC60 SWCG, Turbo System 20 In Floor PopUp Heads Cleaner, Zodiac Auto Cover, Pentair EasyTouch 8 Controls & Screen Logic Interface w/APP for phone remote access, InterFab Slide, FiberOptic perimeter lites, TestKit TF100!!! The BEST & the Taylor Speed Stir - A MUST HAVE!!!
    MugZona's Avatar
    Jun 2014
    60
    Thanks, TeamNelson! I've learned a ton just lurking, too. Can't wait to have a trouble-free pool.
