Results 1 to 11 of 11
Thread: Small mouse in pool...
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    122
    I just shocked the pool due to overfilling it and got all the levels back to normal. This AM I found a small mouse in the skimmer dead. Do I shock again or leave it alone?
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Small mouse in pool...
    I would shock it just because I do not want any mouse cooties in my pool. Ewwwww We had a bat one time. I shocked for that.
    Kim
    38,547
    What does "shock" mean?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I found one in my skimmer... well I found about 1 per day in my pool for about a week. They must have been thirsty. Usually I would catch them the morning after they fell in, in the skimmer. One day I didn't catch it until the evening after a hot day. So needless to say, when I opened the skimmer cover, it didn't smell like roses. I removed the mouse and put about a cup of bleach directly into the skimmer while the pump was off. I used a toilet brush to scrub the bottom, sides, lid of the skimmer. I then checked the FC and pH as I do daily later in the evening when the pump was running and noticed no difference from a normal evening test and bumped it to 7 FC instead of my normal 5-6 overnight. No issues since.
    Isolated Spa - 345 Gallons
    Apr 2014
    Indiana
    106
    I don't worry about it. There are tons of germs from all kinds of sources that regularly enter the pool - that's why we use chlorine in the first place.
    I did run across this from the CDC though: If the CDC says "don't worry about it" then you know it's not big deal, lol. They say 2 ppm chlorine will do the trick and I think we all use more than that on a regular basis.
    For what it's worth I get about 3 mice a month in my pool and my chlorine never drops below 3.5.
    22,000 gallon in-ground kidney-ish shape: 1 HP pump and Triton TR60 sand filter. NEW: Dolphin Nautilus robot! :)
    Oct 2013
    Chapin, SC
    1,141
    I've never seen a mouse in my skimmer-- lizards, frogs and sholderless critters yup.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2012
    Tallahassee, FL
    30,672
    Said the wrong thing when I said Shock. I should have said I raised my FC to SLAM level for the night and let it drift down with sun/time.
    Kim
    Oct 2013
    Chapin, SC
    1,141
    Semantics Schmantics. If I'm not mistaken, Shock IS the correct term as the first thing in SLAM. Since you had no reason to slam, shocking was appropriate.
    Jul 2014
    Liverpool NY
    122
    Shock=scare the bacteria out of the pool with an army of little chlorine monsters, that yell: I am so alkaline I will scare the living acid out of you
    Jul 2014
    Liverpool NY
    122
    Quote Originally Posted by chjade84 View Post
    Oh I am more than 2 ppm regularly, mostly around 3-5 ppm, I also do tablets with BBB as I get a lot of rain and get to drain the pool and lose CYA. I guess I am good then.
    Jun 2007
    New Jersey
    653
    I get 3 or 4 per season average for the 50 years I have been running a pool in the same location (on the edge of a hay field). I have never done anything other than throw the corpse back in the field it came from.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
