Results 1 to 10 of 10
Thread: My TF100 came in today and here are the results. Wondering where to start.
    oldcaptainrusty's Avatar
    Jul 2011
    Jacksoville, Florida
    9
    Smile My TF100 came in today and here are the results. Wondering where to start.
    Tested the pool with my TF100 for the 1st time today. The numbers are:
    Salt 3600 ppm (Intex SWG recommends 3000 ppm)
    CYA 40
    FC 2ppm
    CC 0
    TA 110
    pH 8.2
    CH 475
    Plugged in all the numbers in the Pool Math based on the TFPC in conjunction with the Water Balance for SWGs recommendations in the Pool School.
    I understand how to do the recommended adjustments but have a couple of questions.
    1. To adjust the TA it said to lower pH to 7.0 - 7.2 with acid and then aerate to increase the pH. The only aeration that I have is pointing the discharge nozzle toward the surface of the pool, a little rain and a little pool activity; typically 3 or 4 hours a week. How long could I expect it to take to bring the pH back up to acceptable levels?
    2. With my CH at 475 do I really have to be concerned with a vinyl pool?
    My water is crystal clear right now as it has been since I opened the pool the 1st of the month.
    Thanks
    5200 gal, vinyl AG pool, Intex 1600 GPH pump with 14" sand filter, SWG, new 7/14, TF-100 test kit, Speed Stir
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You'll get aeration from your SWG. Don't sweat the TA. It will take care of itself by keeping PH in range. Lower the PH now with acid.
    Add some bleach to get your FC up also. 3-7 FC level for your current CYA level.
    Don't be concerned about the CH either.
    You should raise your CYA to 70-80. I would go to 70 and see how that works out. 😎
    Jeff
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Re: My TF100 came in today and here are the results. Wondering where to start.
    Welcome to TFP!
    I can't tell you about the TA or CH, but I can tell you that some people don't mess with the TA unless it causes pH shifts often.
    Also, for a CYA level of 40, the minimum FC level needs to be 3 ppm. The recommended level is 5 ppm. See this for more information.
    An unbalanced pH level will cause the chlorine to not be as effective, so you should work towards bringing that down. Also, btw, if your chlorine level ever goes above ~10 ppm, th pH can read falsely high.
    Quote Originally Posted by pwrstrk View Post
    You should raise your CYA to 70-80. I would go to 70. ��
    Should the CYA be that high for the OP, because of his/her location? I'm wondering, because a lady at the pool store told me to keep my CYA near 90 ppm, because I'm in Florida. I just assumed she was incorrect.
    Bobby (my pool)
    18,000 gallon in ground/white plaster
    Flotec pump/Aquatech MYB100 single cartridge filter - runs 6 hours/day in evening during summer
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    OP has a SWG. CYA level for SWG is 70-80.😎
    Jeff
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Oh, thanks. I thought 90 ppm seemed a little high. That lady also said that CYA evaporates with the water, lol.
    Bobby (my pool)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    90 is a bit high IMO. 50-60 in FLA. For a non SWG pool would be fine I would think. 😎
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    tell her to prove both her 90 recommendation and that CYA evaporates. If she can come up with any unbiased scientific data, then believe her.
    for unbiased scientific on both accounts from TFPC, search the Deep End forum. Chemgeek explains it magnificently.
    Quote Originally Posted by ThinkPad View Post
    Divin Dave,
    Jul 2011
    9
    Thanks to all. I'll get my FC and CYA up and bring my pH down and keep an eye on everything else. This forum is great. It sure makes pool care 'Country Boy Proof'.
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    http://www.troublefreepool.com/threa...+effectiveness
    With CYA in the water, chlorine's effectiveness is less dependent on pH.
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    Jul 2014
    Peoria, IL
    389
    Lots of peeps on here that wished that was true. Save a lot of water bills.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
