Thread: stripped drain cap plug on Pentair cartridge filter
    Jun 2014
    Alexandria Virginia
    18
    The plastic drain cap plug on my CCP320 filter is way too difficult to reach and remove.
    Also, mine survived four removals before the plastic nut stripped and it impossible to grip and remove.
    Before investing $35 in a new flimsy plastic one, I thought I'd poll the forum to see if anyone has invented a replacement that is either accessible or metal or both.
    Jul 2011
    Perrysburg, OH
    88
    Re: stripped drain cap plug on Pentair cartridge filter
    I have a Hayward cartridge filter but I believe you can replace the cap with a 3/4" spigot valve for ease of draining...
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I'm pretty sure a standard 1.5 inch threaded plug from home depot or Lowe's will work. You may need a little Teflon thread tape. A $3 fix.
    Maybe this link will give you an idea: http://www.troublefreepool.com/threa...lumbing-SOLVED
