Thread: Cal Hypo
    May 2014
    KY
    17
    Cal Hypo
    Hello, I'm new new TFP this season but everyone has been a tremendous help. Stabilizer is down and have gotten away from tablets completely and been using bleach and liquid chlorine. I have been told I can use the proper dosage of Cal Hypo (65%) directly into skimmer for my chlorine as well. Any advice on this??
    Thanks again,
    18,311 gal. 17 x 32, vinyl, in-ground, 1/2 hp hayward pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Cal Hypo
    Whether or not it's a good idea depends on your current CH reading. Why trade CYA buildup from trichlor pucks for Calcium scale from Cal-hypo? How to Chlorinate
    If you do choose to use it, it's probably best to dissolve it in a plastic bucket and then trickle it in front of the return the same as bleach.
    May 2014
    KY
    17
    Re: Cal Hypo
    Makes sense, thank you for the feed back
