Thread: New pump, filter, plumbing and stenner
    Jun 2014
    Yorktown Heights, NY
    28
    So I went kind of crazy and replaced all of my pool equipment. The old pump was an energy hog and leaked, the old filter was on its last legs and I couldn't get the lid off, and the water wasn't super clear.
    Here's the old:
    Note the disused heater plumbing and pressure side cleaner pump which died. The check valve to the spillover spa was also broken so the spa level would drain down when the pump was off. Pump drew around 1300 watts.
    Here's what I installed:
    I upgraded to all 2" pipe (old was 1.5"), replaced the check valve and all other valves. New filter is a Hayward Swimclear c4030 and the new pump is a Hayward EcoStar. I tried to minimize pipe bends as much as possible. Stenner pump installed too for liquid chlorine injection. New pump draws around 250 watts to produce the same flow as the old pump and the water is CRYSTAL clear with the new filter. Super happy with the upgrade so far!
    Next on my list are LED lights and a robotic cleaner.
    23,000 gal plaster pool w/overflow spa
    Hayward EcoStar pump
    Hayward c4030 425 sq. ft. cartridge filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New pump, filter, plumbing and stenner
    You're done SLAMing when:
