Thread: winter pool cover do I need one
    Jul 2014
    el paso tx
    17
    Question winter pool cover do I need one
    I live in southwest texas, I have a supersplash above ground pool do I need to cover the pool? Can I make my own pool cover?
    Re: winter pool cover do I need one
    Welcome to TFP!
    There is no need for a cover during swim season. You don't really need a cover during the winter either, though I recommend using one. A cover makes it easier to remove debris that would otherwise accumulate in the pool.
    Apr 2014
    FOUR cORNERS
    111
    Hi Marymarm, I live approx. 9 hours north of you, also in southwest(my wife is from El Paso), my suggestion is get a solar cover, cut it fit your pool,leave it on all winter,water will never freeze, you very rarely hit the freezing temps, cover will keep the dust and dirt out, specifically in the spring you know what I mean. we do have a hard freeze up here it only lasts a couple of months though!!
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    I covered my pool last winter, what a PITA! This year I am buying a leaf net or leaving it open.
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    Jul 2014
    el paso tx
    17
    Thanks all! No pool cover but will will put net for leaves
