Thread: Foam on top of water
    When I turn my pump on the water becomes covered with a white foam. Water seems to smell good and clean and is pretty much clear. Couple questions, 1, what is the problem and how do I fix it. 2, is is safe to swim in while the foam is there?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Foam on top of water
    Welcome to TFP!
    Have you recently added any algaecide or other chemicals? Do you have recent test results that you can post.
    Jul 2007
    Waterford Michigan
    36
    Willie, please post some test results and someone will be along to help. Please to insure that you give Ch, Ph, Alc, and of course FC and CYA. If I recall this could be a Ch problem but without numbers we can't help
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
