Thread: Pool Dimensions
    Jul 2014
    Surrey, United Kingdom
    6
    Question Pool Dimensions
    I am trying to plan the installation of my new 12 x 24 Intex pool.
    I would like to have it as close to my existing deck as possible so it gives the appearance of an in-ground pool from the deck/house. If someone already has this pool set up it would be a great help if they could answer my questions below, it may involve a little measuring but I would be really grateful.
    With reference to the diagram below, could someone answer the following for the 12 x 24 pool?
    1) Do dimensions A & B give the maximum width & length of the pool wall including ballooning (12 x 24)?
    2) Do dimensions E & F give the size of the frame? which is in fact less that the stated size of the pool(10'8" x 22'10)?
    3) What are the dimensions for the spacing of the support bars along the length of the pool?
    Thanks
    Simon
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Pool Dimensions
    Q1: Yes
    Q2: E and F are the dimensions of the top rail.
    Q3: C and D are the outer dimensions of the BOTTOM of the support rails - where they rest on the ground. That's the footprint of the entire setup.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jul 2014
    6
    Re: Pool Dimensions
    Thanks for you reply GC.
    With Q3 what I was after was the width of each of the u-shape support hoops and the spacing between them long the length of the pool so I can get an idea as to whether they fit between the existing deck supports. something like...
    18" from corner of pool to first leg of first support, then 18" to second leg of first support, then 2' from to first leg of second support and so on.
    My pool hasn't arrive yet so I am trying to get as much preparation done as possible beforehand.
    Thanks
    Simon
    Jul 2011
    844
    Re: Pool Dimensions
    Sorry, I don't know the answer to that question. If anyone has the same pool and could take a measurement for you, that would be the definitive answer. How about your neighbor's? Any of them with the same pool?
    Bestway SWG
