Thread: Adding acid without pump on myth
    LeimLife's Avatar
    Jul 2014
    Cleveland, OH
    25
    Split by moderator from HERE as it perpetuates a myth and contradicts with our teachings. jblizzle
    Shut off your pump and let the water go still. In the deepest area of the pool add muriatic acid in a steady pour to create a column of acid in the pool. This will eat up alkalinity and lower the ph. If you have a plaster pool do this over the main drains, if it is shallow pour several columns around perimeter an arms length from the wall. Acid is heavier than water and too much too fast could hit the bottom of the pool depending on depth. Wait about 5 minutes and turn the pumps back on. Wait for the water to stir a bit then test again. Always seems to work for me.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Adding acid without pump on myth
    See the threads The Myth of Adding Acid, Acid column myth, and Acid Columning. It is simply not true that the way you add acid has ANY different effect on the amount that TA is lowered. TA is ALWAYS lowered by exactly the same amount based on the amount of acid you add and has absolutely, positively nothing to do with how you add the acid. Adding 25-1/2 fluid ounces of full-strength Muriatic Acid (31.45% Hydrochloric Acid) to 10,000 gallons of pool water lowers the Total Alkalinity (TA) by 10 ppm no matter how you add it. However, adding it in one place with the pump not running can damage the plaster and is completely irresponsible.
    What is true is that both aeration and an overall low pH increase the rate of carbon dioxide outgassing and this removal of carbon dioxide raises the pH with no change in TA. So a combination of aeration and acid addition, especially when done at low pH, results in the most efficient way to lower TA and to do so without risking damaging of plaster surfaces.
    LeimLife's Avatar
    Jul 2014
    Cleveland, OH
    25
    Ok so. Aeration/acid addition + low ph = Off gassing which raises pH and lowers alkalinity.
    Tgis is going to take me a minute I have to forget pieces of incorrect information and then learn what is correct.
    -:-:-:-: Scrambled:-:-:-:-
    pool- adj. A hole of any variois size that you throw stacks of 20.00 bills into
    Jun 2013
    East TN
    309
    Quote Originally Posted by LeimLife View Post
    I use the methods here and that is simply not true. I have an 18,000 gallon pool and we spend about $10-12 a week in chemicals. You will find many people here that spend a minimal amount on their pool. I understand you learned from a different teaching but take some time to read pool school if your not closed minded. No one is perfect but there are some smart and helpful people on this forum.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    pool store- noun, A hole of any various size that you throw stacks of 20.00 bills into
    That's more my experience.
    Isolated Spa - 345 Gallons
