Thread: Resistance Check on Primary and Starter Windings
    Mar 2012
    Maryland
    87
    Does anyone know what the General resistance should be on the Windings of a 1.5 HP a.o smith?
    Thanks
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    22,548
    Re: Resistance Check on Primary and Starter Windings
    What problems are you having that make you want to test the windings?
    Winding continuity should be pretty low and winding to frame should be real high.
