Thread: Much difference between the OmniLogic and ScreenLogic?
    May 2008
    Marana AZ
    45
    My pool is pretty simple. No spa, salt, water fall, solar and LED Light. For this setup is there really much difference between the OmniLogic and Pentair's ScreenLogic? Which would be less expensive and is one significantly better?
    not a pro's Avatar
    Aug 2014
    Quartz Hill, Ca
    1
    Re: Much difference between the OmniLogic and ScreenLogic?
    Just had omnilogic installed. The awesome thing about it is that you are not limited to pool automation. You can add so much more. The rep explained we can have our backyard lighting, outdoor sound system and/or christmas lights added to the system which can all be controlled with our phones, iPad, desktop or laptop. We set up themes so with a push of a button, we instantly have a variety of presets to choose from. We got a super special pre market price, under $1500. Rep said it MAY hit the market in two months or so and starting price for the panel only will be around $2,000 to distributors.
    25,000 gallon pool, IG, plaster, solar heat and gas heater, spa, two water features, pentair DE filter, Hayward VS pump, Omnilogic controller
    May 2008
    Marana AZ
    45
    Quote Originally Posted by not a pro View Post
    I was just quoted $1330 and am not sure. If it jumps to $2000 I defiantly not getting it.
