Thread: Lights out on Mineral Springs unit
    Jun 2014
    Bloomington (Minneapolis), MN
    110
    Hey all, I'm a new pool owner as of last year and am having some problems with my Mineral Springs unit. About a month ago I installed a new cell and it has been running great, my salt level is 3100 and has been holding steady. We left for the weekend on Thursday night and when I got home today to clean out the pool the water was very murky and has a greenish tint to it. I checked the MS unit and all the lights are off. There is still power to the unit because the salt reading is still visible. I turned the power off and back on, the no flow light came on as normal, but when it went out all the other lights remained off. Normally the power on and generating lights glow steady green. Any ideas on what's going on? Appreciate the help in advance!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,212
    Re: Lights out on Mineral Springs unit
    Can't help with your SWCG issues, but until you get them sorted out you need to get chlorine in the pool. From your description you will probably have to SLAM it, but chlorine in it now will help. Have you tested the water? What does the current chemistry look like?
    At the top of the page is Pool School - check out the article on SLAM -Shock Level and Maintain.
    Support the site
    Oct 2013
    Chapin, SC
    1,141
    The power on light should be on whenever power is applied, not necessarily so for the generating light which is determined by a number of factors no flow, high/low salt, voltage/watts etc. Sounds to me you have a blown fuse or some other power issue. I'm not familiar with your system so I really can't give conclusive advice. Good luck with it!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jun 2014
    110
    Apparently this is a common issue, found a thread with a fix http://www.troublefreepool.com/threa...-not-on/page12. Thanks to those that replied!
    Jun 2014
    110
    Replacing the limiter fixed my problem! Anybody know if it's ok to leave the SWG on super chlorinate until my water is clear?
    38,540
    You would be much better off, turning the SWG off and following the ShockLevelAndMAINTAIN Process to clear up the pool.
    Were you not supplementing the FC with bleach while the SWG was not working?
    Can you post up a full set of test results?
