Results 1 to 8 of 8
Thread: Need Help with Pump Motor
    May 2014
    Maine
    32
    So, I need to replace my pump motor. It turns on, hums for about 5 seconds, and then shuts itself off. It's progressively been getting louder the past few weeks, and I was just waiting for it to die. I've tried replacing the capacitor, but it didn't work. I'm pretty sure it's the bearings. The problem is, the pump motor appears to be a discontinued one.
    My pump motor # is C48L29104, It Is a 1-1/2 - 1/4 2 speed motor, 230 V, 3450/1725 RPM.
    I found this pump motor:
    http://www.inyopools.com/Products/00200017003529.htm
    It matches all my specs, but my motor does not have the top mount capacitor thingy on top. Will this still work? My pump is a Max E-Pro, but that is not one of the ones listed under "used on the following models."
    Can I get another motor as long as it matches the specs I listed? How do I know if the mount is the same? Is there only 2 styles (square and circle)?
    IG 16'x37' Vinyl Pool (25,000 gallons); Sta-Rite Cartridge Filter
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Need Help with Pump Motor
    What "specs" did you match?
    What is the service factor of the old motor?
    What is the frame of the old motor?
    If you can post a picture of the motor label, it would help.
    Mark
    May 2014
    Maine
    32
    mas985's Avatar
    Pleasanton, CA
    11,737
    The motor you picked out should work fine but have you thought about downsizing too? 1 1/2 HP is a little large unless you have a spa or other water feature. What is the size of your cartridge filter?
    Mark
    May 2014
    Maine
    32
    Cartridge Filter is 400 sq. ft. I only run the high speed for vacuuming and run the low speed (~6 hrs a day) the rest of the time for circulation. I am going to order the 1-1/2 hp motor mostly b/c I don't want to have to worry about changing the impeller and messing with the current set-up of the pump.
    Robert.wolfe's Avatar
    Jul 2014
    Dallas, tx
    25
    How many gallons is your pool?
    May 2014
    Maine
    32
    25,000 gallons. I replaced the pump motor yesterday. It took me about 2 hrs and I was not confident about my shaft seal replacement, but there have been no leaks yet.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Great job Joe! If it's wrong it will leak pretty quickly. Sounds like you got it done!
