Results 1 to 11 of 11
Thread: Help: Intex pump died
    jmcdtucson's Avatar
    Jun 2014
    317
    After only 2 weeks of operation my Intex 1500gpg sand filter pump has died. It started to make screechy noises the other day, and now it just kind of hums when I start it, but there is no pumping action.
    What do I do while I'm working on getting a replacement under warranty? Should I shock it so the water stays clean?
    Any advice on working with Intex? Or am I missing something I could troubleshoot?
    Thanks!
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Help: Intex pump died
    Keep your testing up, and dose as needed. If you have kids, have them mix the water by running in circles, jump out, you dose, wait 10-15 min, have them do it again. Brushing the pool also helps mix the water. I think you may be able to do this for a few days.
    You pump probably uses skate bearings, 608 Z, ZZ or RS. Easy to replace, if you don't mind invalidating the warranty. The screeching was probably the bearings seizing up. If you remove the top cover, you should be able to reach the cooling fan. See if you can get that to move.
    Orlando, FL
    690
    You can get a new pump on Amazon for about $60. It will arrive in a few days and you will always have a backup.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    jmcdtucson's Avatar
    Jun 2014
    317
    Here's the unit I have. I think if I get another one I'll get the 2650 gph.
    http://www.ebay.com/itm/INTEX-Krysta...-/350555324607
    I still think I'll have them replace it, the 1600 gph seems fine for this pool. Until then I can use bleach and the kids are perfectly capable of stirring it up.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    You say it's just a couple weeks old? Intex will replace it under warranty.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    jmcdtucson's Avatar
    Jun 2014
    317
    I called Intex and they should be sending me a new pump. So now the waiting begins. Last time I dealt with Intex they were very fast. Any one have any experience? I'm leaving for a week in 6 days so I'm wondering if I need to buy a backup pump motor.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Jul 2011
    844
    I am in eastern Canada, and Intex shipped me a new pump from the U.S. If I remember correctly I received it in about a week.
    Bestway SWG
    jmcdtucson's Avatar
    Jun 2014
    317
    Intex service is great. This is the 2nd pump I've had die (2 separate pools) and both time they shipped me a new motor quickly and with no hassle. I upgraded to a bigger filter (3000 gph) and will keep this motor as a backup.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Sep 2013
    Joplin, MO
    74
    I just got off the phone with them because our 2100GPH pump is making crazy noises, they're replacing it no questions asked. I just have to figure out the same issue, if it quits working getting bleach in the pool. I'll be gone this weekend praying it holds out. I've only been running it enough to mix in the bleach.
    Pool Owner since 2013 . 15'x48" AG Intex Metal Frame . 4500 Gallons . Intex 2100 GPH Sand Filter
    jmcdtucson's Avatar
    Jun 2014
    317
    Good luck. I suppose you could bring the chlorine up high enough before you leave so it will be back to normal once you get back. That was my plan before I ordered the replacement/backup pump on Amazon.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Sep 2013
    Joplin, MO
    74
    I've been trying to keep it somewhat high just in case that happens. It's crazy when you've always had sparkly water to worry about coming home to it green!
