Results 1 to 7 of 7
Thread: 3 Met O Plus and metal stains
    Apr 2009
    Burlington, ON, Canada
    344
    I've been battling metal staining in my pool for most of this season. Ascorbic Acid in the form of vitamin C works well and so does Citric Acid (Natural Chemistry Stain Free for example) in removing the stains. The local pool store suggested 3-Met-0 Plus by Sani Marc (note 3-Met-0 is a liquid sequestrant, the 3-Met-0 Plus is a powder). The label mentions that it 'contains' Sodium Bisulphate. This video shows it doing an impressive cleaning job - http://www.youtube.com/watch?v=AUClby0bVGU
    Does this stuff have any benefit or drawback compared to Ascorbic/Citric Acid? Does it consume chlorine like the Ascorbic/Citric?
    Thanks.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: 3 Met O Plus and metal stains
    Sodium bisulfphate is dry acid so nothing special there -- it just lowers pH. There may be other chemicals in it but I can't find an MSDS so I can't tell you about it.
    Apr 2009
    344
    Thanks. I couldn't find an msds either. There must be something else in there then besides the sodium bisulphate. I'm wondering if it's just ascorbic or citric acid (the video looks a lot like what happens when those are added to a stained pool) with the sodium bisulphate to lower Ph to prevent the stains from reappearing.
    Apr 2009
    344
    Well I have an msds. Anyone know what this stuff is and any plus or minus compared to ascorbic acid? . Thanks.
    Main ingredients are
    2,3-didehydro-D-erythro-hexono-1,4-lactone
    and
    sodium hydrogen sulphate.
    2,3-didehydro-D-erythro-hexono-1,4-lactone is the mirror isomer of ascorbic acid, and so will do the exact same thing for our purposes.
    Sodium hydrogen sulphate is what we call dry acid. It lowers PH with no specific stain removing properties.
    Since you are getting less than 100% ascorbic acid, you will need more of this stuff than you would of ascorbic acid.
    Apr 2009
    344
    Thanks for the reply. I guess they add the sodium hydrogen sulphate to lower the pH and reduce the risk of staining - however, I'm quite happy with my pH level where it is. I wish bulk ascorbic acid was easier to source here in Canada. Do you have any idea why they would use the mirror isomer instead of just using ascorbic acid? Is it cheaper or more effective? I'm not a chemist, so I had to Google mirror isomer...lol.
    Also, so many different names and formula for the same thing - I think the 2,3-didehydro-D-erythro-hexono-1,4-lactone is also known as Sodium Erythorbate (mentioned once in an old thread here http://www.troublefreepool.com/threa...-Stain-Removal )
    Mar 2007
    San Rafael, CA USA
    12,082
    It may be cheaper though as far as I can tell ascorbic acid seems less expensive online. And yes you are correct that the chemical is also known as sodium erythorbate.
