Thread: Sand Filter Question
    danoammo's Avatar
    Jul 2008
    Haughton, LA
    2
    I have a 150lb sand filter. I purchased 3ea 50lb pool filter sand bags from home cheapo (hence 150lbs). I put all three bags in, however the filter is 3/4 full. Does the sand need to be close to the top of the pvc pipe in the filter? Say a few inches from the top? Also, I turned it on for the first time and for roughly a minute sand came out untill it cleared. Is this normal, or is my pump too strong for that size filter?
    27'x27'x4' AGP, 1.5hp motor, 150lb sand filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sand Filter Question
    It's normal for it not to come to the top of the filter. There's some turbulence inside. It's also normal for some sand to come out when you first start it. It's best to rinse for a while before filtering with new sand.
    danoammo's Avatar
    Jul 2008
    Haughton, LA
    2
    Great, thanks for the quick reply!
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    You must backwash not just rinse 3/4 full is correct. backwash then rinse until clear at least 2 times before you use.
    happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Jul 2008
    144
    A 1.5 h.p pump on a filter that only takes 150 lb of sand sounds too big. A 1.5 h.p pump will usually deliver about 60 to 85 gpm. A filter that takes 150 lb of sand will typically have a design flow rate of about 40 to 45 gpm. What is the flow rate listed on the filter?
