Thread: Shocking question
    May 2014
    North Haven, CT
    4
    Shocking question
    For my spa, if my CC stay at or below 0.5, do I really need to shock weekly? Is the thought that if you don't shock weekly, the CC will inevitably climb? Right now, my bather load is very low - 2 or 3 uses per week at <15m each (2 people). Also, if I shock it to a high FC and the chlorine demand is low, won't it take days for me to be able to use the spa w/o an undesirable chlorine presence?
    I apologize if these are basic questions, I am still trying to get my bearings. One last one - assuming I have stable CH, TA, CYA, and pH levels, is CC really my key indicator for spa water quality?
    Thanks.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Shocking question
    No, you do not need to shock weekly, especially if you are using chlorine for your spa.
    What method of disinfection are you using? Dichlor-then-bleach? Dichlor-only? Bromine tabs with bromide bank? Nature2 with MPS? Do you have an ozonator?
    May 2014
    North Haven, CT
    4
    I am using dichlor-then-bleach from Nitro's "How do I use Chlorine in my Spa (or pool)?" No ozonator at present.
    Mar 2007
    San Rafael, CA USA
    12,082
    OK, then you should be in great shape and your CC should remain low though keep in mind that it will be high after you add chlorine right after your soak, but will drop within hours as it oxidizes bather waste. It should be low in time for your next soak.
