Thread: Pool sand/Filter media - pea gravel, silica, zeo
    May 2013
    Western Washington
    18
    Hey there helpful people,
    Looks like its time to replace the Zeobrite in our sand filter. We purchased the home 3 years ago and the sand at that time was about 5 years old. Lately we are seeing sand on the bottom of the pool coming from the cleaning heads.
    Given that we need about 600lbs of sand or a sand/pea gravel combo - what are your thoughts? Looks like with the Zeosand on Amazon we would need about 150lbs.
    Thoughts on what to use? A pea gravel/sand combo?
    All Silica?
    Zeo?
    Thanks you!
    40K gallon IG pool w/ a spa inset; Gunite; in-floor Caretaker system; Triton 2 tr-100 sand filter w/ Vitroclean
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Pool sand/Filter media - pea gravel, silica, zeo
    Hi Kathleen,
    I dont know of any really negative comments about zeobright, other than it does have to be replaced every few years.
    Sand is prefectly fine filter media. Many folks use a cup or 2 of DE added to the skimmer after every backwash to increase teh filtering capability of sand. Sand doesnt wear out and so never has to be replaced *contrary to what the pool store will tell you*. It does need a good deep cleaning with a water hose every 2 or 3 years though.
    Do not use pea gravel in your sand filter. It may very likely break the laterals and will degrade the filtering capability of the sand.
    Hopefully others will also chime in with better info than what i can provide.
    Divin Dave,
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Regular old filter sand! You can get fancy and top it off with a cup or two of DE if ya' like.
    May 2013
    Western Washington
    18
    Our filter calls for #20 Silica Sand - is this different than pool sand?
    Apr 2010
    East Texas
    9,609
    That's what you want!
