Thread: Intelli pH install
    Intelli pH install
    Quick question for everyone who has experience with this unit.
    I know that the literature recommends installing the feed tube before the companion Intellichlor SWCG.
    This is the exact location of the booster pump's cleaner line, making it a very cramped install. Would it be improper to instead install the dispensing tube before the
    cleaner line?
    Thanks in advance for your input !
    21K gal, IG plaster, 1/2 HP WhisperFlo pump, 60 sqft Titan RPM Vertical Grid DE filter
    Re: Intelli pH install
    Welcome to TFP!
    You don't want the acid injection before the cleaner branches off. That would subject the cleaner to low PH, which isn't a great idea.
    If there is absolutely no way to get it in-between the cleaner and the SWG, I would install it after the SWG.
    Thanks Lion.
    That was pretty much the conclusion I came to after being on site again. I'll try and post up some pictures when all is done!
