Thread: Pump trouble- maybe impeller(?)
    People,
    Pump runs, but no circulation, so I removed the basket, cleaned it, and with clear plastic basket cover off, I started motor- motor starts, but doesnt draw in water from basket/pvc tubing. Where would you start dismantling? What is suspect? Impeller, right?
    Thanks
    16,000 gal in ground, marcite. FL.
    Re: Pump trouble- maybe impeller(?)
    Well, started unscrewing, figured what do I have to loose- have a broken impeller. The stamp on it says c105-92ps. I take it as long as I order that code, should have no problem- please confirm, if possible.
    Thanks
    Smykowski's Avatar
    Sep 2011
    3,065
    That sounds correct. I would cross check the pump make and model with a parts explosion to be sure
    Quote Originally Posted by Smykowski View Post
    Thanks, Smy.
