Thread: MA Shock Question
    Jul 2014
    Iselin, NJ
    26
    MA Shock Question
    Quote Originally Posted by Casey View Post
    But you did not use your robot in the pool at MA SLAM levels did you? He is going to SLAM to higher values and it's not recommended.
    Casey, that's true, I forgot he was at MA SLAM levels...then again, that brings up a good question that would be handy for future reference (my apologies if this is answered somewhere else); I know it's safe to swim at SLAM levels relevant to your CYA, but what about MA SLAM levels? Is that way too high, or would it be ok for a short period of time?
    30K gal IG vinyl, Hayward S244T sand filter, Hayward C48L2N134B1 Self Priming Super Pump
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Brush the floor?
    I believe they usually word it "up to" slam level. Meaning if you are at or above SLAM target, you probably shouldn't swim. Thought MA is done after you initially pass OCLT and you go to MA level for a day or two. But I could be wrong, I haven't had to use the process.....
    Casey's Avatar
    SW PA
    10,427
    Re: MA Shock Question
    Usually, MA SLAM levels are only held for 24 hours so swimming won't be delayed for long if you ever need to do it.
