Thread: Running Filter After Chemicals - is it necessary?
    Jul 2014
    Northern Minnesota
    51
    Just wondering if it is best (or necessary) to run the filter for a few hours after putting in chemicals at the end of the day? Is it the end of the world if you are not able?
    Intex 15 ft x 42" Above Ground Pool bought from Amazon (3, 284 gallons)
    Standard pump and cartridge filter that came with the set up (1,000 gph)
    I live in Northern, MN
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Running Filter After Chemicals - is it necessary?
    It is best to run the pump 30 min before testing, then run the pump an hour after dosing.......Thanks for the reminder, I need to add a bit of FC to my pool!
    Casey's Avatar
    SW PA
    10,461
    I run at least an hour after additions to mix it.
