Thread: Just experienced my first liner separation
    Hello all--just experienced my first liner separation. Of course it was while I was on the plane getting ready to leave on a trip and my wife called. Always that way, right?
    So I read a bit here (thanks a bunch) and had no trouble getting the liner bead back into the channel, or at least "started" to get it in. It feels like it needs to go down quite a bit more.
    So my first issue is that I can't get to the channel from above because of the metal edging-- I was about to remove the edge when I realized it might be structural-- is it? Can I remove this safely to get access to the channel from above? I sort of have 2x4's bracing the edges just in case, but I'd rather not find out too late that it didn't work.
    And if I can get said access, I read all about popsicle sticks and pennies, and if that doesn't work I'll look into the liner lock product.
    Sorry-- absolutely NO idea why the pics are coming out upside down. Second try even after I flipped them on the computer.
    Casey's Avatar
    SW PA
    10,428
    Re: Just experienced my first liner separation
    Welcome to TFP. You will be able to safely remove 3-4 pieces of the top rail without having the pool collapse. I wouldn't remove more than that at a time though. If you need help stretching the liner, HOT WATER works like a charm.
