Thread: Oil/ foam on top of pool
    Jul 2014
    clifton park Ny
    1
    During this summer every time I put chlorine amd algecid into the pool this foamy oil stuff comes up, the green pool is the foam about 5 hours before the picture with a blue pool, I would like to know what this is and how to prevent it
    http://tinypic.com/view.php?pic=qn4fg8&s=8#.U9RCxRnD_qA in years past
    http://tinypic.com/view.php?pic=auxvmt&s=8#.U9RDYRnD_qA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Oil/ foam on top of pool
    Welcome!
    That foam is probably the algaecide reacting with the chlorine.
    If you follow our methods and maintain adequate FC for your CYA level all the time, you'll never need algaecide. I've never put a drop in my pool and I haven't had an algae bloom in over four years continuously open. If you want to use algaecide as insurance, stop buying the cheap stuff and spend the bucks on Polyquat 60.
    Have you been to Pool School yet?
    Start with Getting Started, especially the first two posts.
    Casey's Avatar
    SW PA
    10,457
